Slow on the progress but its getting there.
Putting the tyga tail was abit of a ^%$£. First time i tried broke a pin epoxy it back on. Figured i had to attach the black panels on it first hold it in place then slide from above.
Haven't attached bars yet need to make 5mm thick spacer under triple and also need bar risers as bars hit forks.
I used Renthal RC fatbars and renthal CL005 clamps.
Wiring and cables and quite good although slightly tighter on right side.
Final check will be when forks a raised to correct height and risers are in.
Also the axle, forks, top and bottom triples were straightened so she's all good.
Also got another project a 07 xt660x
Went down lightly on the left prices for plastics were crazy. $160AUD for light cowling and $160AUD for left shroud. Also put Renthal RC bars on this which look exactly the same as stock.
