With respect, you are new rider, I doubt you are pushing the cbr to levels where you need special damping valves and fork springs.
Just set the sag first, and change the fork oil while you are at it.
I'd look at body position, cornering, and Braking technique long before getting the wallet out.
The cbr has very forgiving suspension for good reason.
You will get smoother at riding.
if you are interested in setting up the sag on your forks, i can explain it to you and get you a ballpark number on preload spacer length tomorrow if you want. It sounds hard but is quite easy really. if you don't want to change the oil you can pretty much do all the work in about 30 minutes. by the way, you were right to think things would shoot out at you. the fork bolts are under spring pressure.
The Following 2 Users Say Thank You to Jme250RA For This Useful Post:
Aufitt, if you don't mind, how much do you weigh for that rear set at 4? Im about 70kg in my gear.
Dave
You are best measuring it on your own bike.
(but Ive dropped from 79kg to 72kg.)
measure at std pos 2 before you start (follow youtube gudes)
measure at 3 & then 4, its not linear.
30-35mm is good for the road but I run 25-28mm now.
Originally Posted by CBR_Dave
Also, to up the front did you just use a length of PVC pipe 7mm longer than the stock tube in the forks?
Regards,
Dave
Like the rear its not linear as to how much it raises as the sping is compressed.
and needs to be measured and checked on your own bike with you on it.
Regards,
Dave
The stock fork springs sag more under just the bike weight than they should with the rider on. That being said you will have to add more like 1"+ to the length of the stock spacer. I don't have any info in front of me but will look into it when I get home.
The Following User Says Thank You to Jme250RA For This Useful Post:
I get it :-) I just meant in principle. Say I wanted 7mm less sag, then in principle do I just need to add a PVC pipe ~7mm longer than the stock spacer? I realise it's not linear so it might be slightly "out", but as a starting point I mean.
Another way to ask is: how long are your spacers compared to the stock spacers :-)
Dave
Eleven hours in a tin can?
