Fork adjusters - Honda CBR250R Forum : Honda CBR 250 Forums
Old 11-06-2012, 11:11 AM   #1
Default Fork adjusters
Ello all, i was wondering if anyone uses fork preload adjusters, and why or why not. I dont know much about them and would like to know more.
G└í┬¢H☺
Stock Black Honda Cbr250r
- 100/55 headlight
Glitch is offline
Old 11-06-2012, 04:14 PM   #2
Fork preload adjusters are an easy way to set the sag on the front forks once they are installed. The only reason I would put a set on my bike would be if I needed to change the preload regularly. The reasons being changing from road riding to track riding or regularly riding two up where you needed to compensate for the extra weight. If it's mainly you riding on the street, then you could just cut new spacers and replace the existing ones to get the sag set correctly. Either way, you need to take the fork caps off so it's up to you whether you want to spend $5 on 1" PVC tubing or $100 on adjusters. I touched on it in step 8 of my fork emulator and spring change thread.
Racetech spring and Emulator Valve install
Jme250RA is online now
The Following 3 Users Say Thank You to Jme250RA For This Useful Post:
Aufitt (11-06-2012), Glitch (11-06-2012), MotoMike (11-06-2012)
Old 11-06-2012, 04:17 PM   #3
I see. What about smooth city to back woods crap road??
G└í┬¢H☺
- 100/55 headlight
Glitch is offline
Old 11-06-2012, 04:25 PM   #4
Here's a video
setting suspension sag - YouTube
Once you set your sag properly, you shouldn't need to readjust it as it is mostly about your body weight.
The Following 2 Users Say Thank You to Jme250RA For This Useful Post:
Old 11-06-2012, 05:22 PM   #5
Ill check it out, thanks!
G└í┬¢H☺
- 100/55 headlight
Glitch is offline
Old 11-06-2012, 06:29 PM   #6
What do eliminator valves do?
2012 CBR250R
Nicholas is offline
Old 11-06-2012, 06:33 PM   #7
I have no idea nick??
G└í┬¢H☺
- 100/55 headlight
Glitch is offline
Old 11-06-2012, 06:54 PM   #8
BBRMotosports's Avatar
Emulators control the dampening of the forks since we cannot adjust them like you can on my sport bikes. In my opinion adjusters are a waste of money unless for whatever reason you need to change the sag often. Keep in mine spring preload does not make the forks stiffer. Same go's in the rear
2011 CBR250R, 04 KTM450SX, 05 CR125R, 2013 CBR500R
BBRMotosports is offline
Old 11-06-2012, 06:58 PM   #9
so what do i need to stiffen front? heavier oil?
G└í┬¢H☺
- 100/55 headlight
Glitch is offline
Old 11-06-2012, 08:09 PM   #10
Glitch (11-06-2012)
