Did you look up the price for the rr piston? Its over $100 just for the piston . I think ill just deck the head for free.
Checking MR again, you are correct as the CBR piston is 108, and the CB is 54. The CB would not yield as high a compression as the CBR, but should also fit.
Big price difference. Wonder if CB piston is just cast.
And clearly both cost more than just decking the head, especially when you have the skill and tools! Best wishes.
Sent from my GT-P6210 using Motorcycle.com Free App
Is there a weight difference between the stock piston and the 1000RR piston? If so, would it throw off the balancer. That's my big question for this mod, whether it be a simple swap or a bigger piston.
I would think that there would be a difference, with the CBR1000R piston forged, while the CBR250R is probable cast and not forged. The lighter, but stronger CBR1000R, would create an imbalance to some degree, but not destructively imbalanced.
I have put together alot of big bore kits in bikes with balance shafts and never had an issue. But like i said im not changing the piston.
