Question about low RPM vs mid RPM - Page 3 - Honda CBR250R Forum : Honda CBR 250 Forums
Old 12-25-2012, 02:42 AM   #21
generally i shift gear 4.5-5k rpm which i feel is for smooth riding..if you wana give a punch then one should take it upto 8.5k..I guess reving upto 9+ in 1st & 2nd gear isnt good for engine.. Correct me if am wrong....
for
smooth ride 4.5-5k rpm
race/fast ride/ to reach top speed asap 8.5k rpm
smartk22in is offline
Old 12-25-2012, 03:44 AM   #22
I consistently (within 0.3 secs) ride as fast & smoothly as my skills and the Nugget will allow, and could pinpoint within a metre when gearchanges are done.
But;
have no idea what gear it actually is
Have no idea what the revs are unless they are over 10,800
No idea what the speed is (unless viewing gps data)
^because that stuff dont matter.
Jme250RA (12-26-2012)
Old 12-25-2012, 10:59 AM   #23
The only time I have ever used a tach to determine when to manually shift anything (cars and bikes) is on any arcade driving game I've played. Otherwise, it's based on the pull and the sound. But that's just me.
nothin2do is online now
The Following User Says Thank You to nothin2do For This Useful Post:
Old 12-25-2012, 12:31 PM   #24
Rory_L's Avatar
My first car was a 3rd(or 4th)-hand Austin Healy Sprite. The tachometer did register something but would mostly swing wildly from stop to stop. Pull and sound was the way it had to be done.
Now the oil pressure gauge dropping to a hair above zero, that I had to believe was true.
The vespa didn't have a tach either (they never did).
. . . It's pointless to race between Starbucks', around here they are 300 yards apart!
Rory_L is online now
Old 12-26-2012, 02:00 AM   #25
when learning to play piano you look down at the keys,
but eventually you dont need to use visual cues..
on a motorcycle, you must maintain attention forward
with primary vision, which may be extended as you become
familiar with riding to include consciously expanding your
peripheral vision to take in more of the front/side view,
together with glancing thru rear view mirrors now and then..
when learning, and thinking of revs and speed, do it on a closed
course or quiet area without traffic and no distractions if possible..
otherwise, generally ride without thinking of the tacho or speedo,
as if they dont exist.. you dont want to develop a bad habit of
drawing your attention and thus mind from the road to instruments..
just as you will learn naturally to ride without having to look down at
the clutch lever as you use it, or the throttle as you apply it,
or the gear lever as you change gears, or the brakes, etc,
so you will learn to maintain your vision ahead in the direction
you are heading and intend to head [such as when cornering]
while still being able to take in momentary glimpses of
tacho [without dropping your head!] and also mirrors..
your brain and body will, learn this and these sequences,,
just as you could learn to juggle or play piano or whatever,
thru intent together with regular rational practice...
riders riding together often ride with different riding styles
incl speed at gear change and so on, while still riding
together as a loosly structured group of riders..
so it doesnt really matter,, exactly what revs
or speed you change at..
over time this will become natural and you will
probably smile when you think back at
how you were concerned about it
its not a bus its a motorcycle..
respect it,, but get out and
ride the thing...
Wynne G Oldman (12-26-2012)
Old 12-26-2012, 02:57 AM   #26
"Shisoshin" (a Haiku)
Shisoshin can write
responses like poetry,,
without periods
phatch is offline
The Following User Says Thank You to phatch For This Useful Post:
