is this start up normal..?? - Honda CBR250R Forum : Honda CBR 250 Forums
Old 06-13-2012, 01:41 AM   #1
Chinmay's Avatar
Default is this start up normal..??
hi guys,
i think there is sumthing bit odd wid my cbr which is been happening recently.
as u kno wen u turn the ignition key on, turn the kill switch on, wait for the buzzing sound, fire up the engine....engine starts normally at approx 1500 rpm (with no throttle) which is perfectly fine...rite..??
but i noticed wid mine in last few days...following exactly the same way as above, it automatically goes to 5000-5500 rpms and at times even more... for no apparent reason... isnt it a bit odd...??
and keeps at the same or gradually increases unless i pull the clutch n shift it to 1st gear... thats when it drops to 1500-1700rpms.
I waited for over 30 secs for it to come down to normal, no luck.
should i b concrnd abt it...is there any thing i m doing wrong ??
any1 out there has similar issue...??
Chinmay is offline
Old 06-13-2012, 01:52 AM   #2
Not normal. Get it into a dealer and have that bike checked out.
Old 06-13-2012, 06:35 AM   #3
KING JAMES's Avatar
Get it looked at immediately.
I DON'T ARGUE WITH IDIOTS, THEY DRAG YOU DOWN TO THEIR LEVEL AND BEAT YOU WITH EXPERIENCE!
KING JAMES is offline
Old 06-13-2012, 09:19 AM   #4
mine does it every now and then, if its rather cold, I just give it a rev to sort it out
My Seat Cowl, And my Tinted Screen are GENUINE HONDA ITEMS! I bought them from HONDA!!!!
Macca is offline
Old 06-13-2012, 11:37 AM   #5
mattcbr250's Avatar
Probably the idle position sensor, if they're on these bikes. Take it in and have it fixed. That's not normal. When cold it really shouldn't go past 2-2.5K while warming up.
mattcbr250 is offline
Old 06-13-2012, 12:23 PM   #6
Yeah something is messed up with the idle thing, or your throttle cable is adjusted (to no foreplay? or negative?) such that no throttle is actually feeding the engine some fuel. Definitely get it checked out, let us know what it was.
Originally Posted by MotoMike View Post
This thread could have been called MILPD or Motorcycles I'd Like to Plasti Dip
From here:
If it was up to me, every motorcyclist that ends up donating his organs though no fault of his own should be matched by the enforced confiscation of the organs of the idiot that ran him over.
65.8 MPG!
Jubis is offline
Old 06-13-2012, 02:09 PM   #7
TX_Dj's Avatar
+1, Definitely not normal. I'd be seriously concerned there's a flaw in the throttle position sensor or a stuck throttle cable or such. Could be an absolutely dangerous situation for you if it decided to do it while you're in motion.
Get it checked.
cheers,
dj
"I'm No Expert"
Motoring on two wheels since 1983
"This old engine has a nickels-and-dimes sound to it. As if there were a lot of loose change flying around inside. Sounds awful, but it's just normal valve clatter. Once you get used to that sound and learn to expect it, you automatically hear any difference. If you don't hear any, that's good." -- Zen and the Art of Motorcycle Maintenance
TX_Dj is offline
Old 06-13-2012, 02:51 PM   #8
Iamahood's Avatar
+1 for getting it in immediately. The buzz after you turn the key is the fuel system coming up.
Sent from my iPhone using MO Free
Iamahood is offline
Old 07-31-2012, 07:03 AM   #9
Happens to me about 50% of the time when starting if it's less than about 12degC. A touch of the throttle and it goes back to 2000-2500 until it's warm.
stevestevesteve is offline
Old 07-31-2012, 12:33 PM   #10
Yeah, I've had it happen a couple times where the throttle just progressively keeps going up and up after I start the engine in the morning. I turn the throttle just a bit and it's fine. It's really only happened two or three times since I bought the bike back in mid-June, so if it's doing it every time I would be more concerned.
Run and Gun is offline
