is my engine seized? - Honda CBR250R Forum : Honda CBR 250 Forums
 6Likes
post #1 of 37 Old 07-04-2016, 05:05 PM Thread Starter
Quick question, if my rear wheel turns when in 2nd to 6th gear with the clutch out does it mean my engine is not seized?
My 2012 cbr 250 it died and wont start back up after redlining it.
thanks
greenleaf
toronto
canada
greenleaf is offline
post #2 of 37 Old 07-04-2016, 05:26 PM
If you can rotate the rear wheel with the transmission in gear and the clutch engaged (lever released) it wouldn't be seized. That said, if the engine is mechanically healthy you should be able to feel cylinder compression when rotating the rear wheel... if you don't and the rear wheel can be turned easily, it definitely means you have little to no cylinder compression. Which would explain why it won't restart.
post #3 of 37 Old 07-05-2016, 09:48 AM
What does it do when you try to start it normally?
post #4 of 37 Old 07-05-2016, 07:35 PM Thread Starter
"What does it do when you try to start it normally?"
when i press the start button, it makes a whirring winding sound (like it did when the bike was running great)
the exhaust makes small backfire noise and some very small faint light in colour smoke rings.
I cant push the bike when its in first gear, 2nd gear is hard to push (there is resistance) but doable. higher the gear the easier it is to push with the clutch out and spark plug in.
I am tempted to push start it again (battery is good on battery tender) but i have put everything back on the bike (i changed the spark plug it was dry but it was sitting for a bit before i replaced it.
I just unplugged the battery, gonna let it sit (just to see if does anything)
post #5 of 37 Old 07-05-2016, 10:40 PM
So when you first turn the ignition key to the 'on' position (with the Engine Stop Switch in the 'run' position), does the instrument cluster light up along with the tach needle going through its sweep? Do you also hear the fuel pump cycle?
post #6 of 37 Old 07-05-2016, 10:52 PM Thread Starter
Yes. instrument cluster lights up there tach.
sweeps across and goes back and it's primes.
post #7 of 37 Old 07-06-2016, 02:31 PM
CBRogers's Avatar
Wouldn't it make sense to try to read the flashes from the MIL and see if you can detect something there?
CBRogers is offline
post #8 of 37 Old 07-06-2016, 03:38 PM
Did it stop abruptly last time you rode it? Has it been sitting a while? Does it sound like it is turning over normally when you hit the starter?
Doesn't sound like it would be seized, but something odd is going on.
post #9 of 37 Old 07-06-2016, 05:42 PM
CBRogers's Avatar
Valve problem from the over-revving?
CBRogers is offline
post #10 of 37 Old 07-06-2016, 11:59 PM Thread Starter
everything looks normal. abs comes on and goes away when in gear.
