Turn signals stopped working - Honda CBR250R Forum : Honda CBR 250 Forums
post #1 of 7 Old 01-11-2017, 08:58 PM Thread Starter
Hello everyone. I noticed that my turn signals are no longer working (all 4 blinkers). The front two stay lit all the time and the back ones never turn on. The other lights are working fine. Any ideas on how to troubleshoot this? There's been a lot of rain here the last few days, and I noticed that water is getting in under the passenger seat.
lightfox is offline
post #2 of 7 Old 01-12-2017, 01:58 AM
Polk's Avatar
The relay might be fried, or the wiring to one of your blinkers (back ones) might be corroded or unplugged. Best bet is to trace wires and make sure they're all plugged in and free of water and corrosion. If they are then I'd check the bulbs themselves and then the relay. Seems more like a blown bulb, though.
Current rides:
2012 CBR250R ABS
2002 WRX
Awaiting registration:
2001 CBR600 F4i
Polk is offline
post #3 of 7 Old 01-12-2017, 09:10 AM
I'd check the fuses as well.
Dry out anything that is wet. Sounds like something may be arcing or a relay or switch is wet.
jkv357 is offline
post #4 of 7 Old 01-14-2017, 02:15 PM Thread Starter
I couldn't figure out where the relay for the turn signals are. I have the service manual but it wasn't clear. Anyone have a good photo of where it is?
lightfox is offline
post #5 of 7 Old 01-14-2017, 10:09 PM
If the front ones are on solid and this happened to all four suddenly, then your wires are likely fine. Sounds like either the switch on your handlebar or the relay is fried. I'd spray some contact cleaner on your switch first. I say this because in U.S. market bikes there isn't really a turn signal relay besides the position relay; the control of the turn signals is accomplished by a control box which is wired into the headlight. If it's an Aussie bike, the relay does exist and is under the front cowl on the left side by the instrument cluster. Both side fairings and the headlight have to be dropped to get to it.
This is a video for an LED flasher relay install on the 300; https://youtu.be/jkvNrPfqheo?t=7m31s. Not sure if it's the same on our bikes.
cbrlocal is online now
post #6 of 7 Old 01-16-2017, 11:31 PM Thread Starter
I opened up the housing for the switches on the handlebar and poked around a little in there. I saw some corrosion on the headlight switch that flaked off when I flipped the switch a few times. I tried the same thing on the turn signal switch, and it seems to be working now. I'm surprised there isn't better waterproofing on the controls.
While I was looking into the relay I found this video for our bikes. Looks like it's different from the 300. https://youtu.be/Ke16R43pzG8?t=89
lightfox is offline
post #7 of 7 Old 01-17-2017, 12:14 AM
I think the Aussie and Indian bikes have that relay. Not sure if U.S bikes do or not; haven't poked at it too much in there.
