water pump cover is leaking a bit. - Honda CBR250R Forum : Honda CBR 250 Forums
Old 10-31-2012, 12:24 PM   #1
Default water pump cover is leaking a bit.
I took my bike down to the power sports shop to get some maintenance done on it and they pointed out that there was a bit of a small coolant leak that looked like it was coming from the return line on the motor. They said they tightened it down a bit and to keep an eye on it. Well I noticed the smell and the leak again. So I wiped the motor off and noticed the fizzy bubbles coming out from around the left top side of the water pump cover, not the return line as previously thought. It looks like there is a gasket there behind the cover http://www.hondapartshouse.com/home.aspx?gclid=CK7k5KbQq7MCFSWoPAodQwUAtg#/Honda/CBR250R_2AC_(11)_MOTORCYCLE%2c_THA%2c_VIN%23_MLHMC 411-B5000001_TO_MLHMC411-B5099999/RIGHT_CRANKCASE_COVER/CBR250R-11-THA-2AC/2Y14KYJBKYJ4E0600B
number 14 (19226-KYJ-901). The dealership is over two hours away and I don’t have the time to take it there. I was thinking of replacing it myself. My question is this, is Honda using a gasket sealer on these gaskets and if so what do you recommend. Also I know I should get the shop manual but does anyone know the TQ specs for the bolts on the cover?
Learning how to go fast is more important to me then doing it. That is why I ride a cbr250r.
7point62fmj is offline
Old 10-31-2012, 01:47 PM   #2
BMX RACR's Avatar
Mine did the same thing, snug the bolts up on the waterpump cover and it should be fine.
Carolina Auto Tint
803-328-6866
2011 red/silver CBR250R
2005 silverstone/black&red S2000
BMX RACR is online now
Old 10-31-2012, 01:58 PM   #3
DamianW's Avatar
The dealership pointed out the same problem to me during my bikes first service. They replaced the water pump gasket under warranty.
File Type: jpg ImageUploadedByMO Free1351706228.773742.jpg (128.5 KB, 64 views)
DamianW is online now
Old 11-01-2012, 04:04 AM   #4
The tell tale will weep a bit as the seal settles over the first few thousand miles.
Its no drama.
firstcbr (11-01-2012)
Old 11-05-2012, 10:07 PM   #5
Its a small leak, I will keep the over flow bottle on my check list in till I get it in for its next dealership stop.
Old 04-14-2013, 12:16 PM   #6
Aww the joy of old problems. This is not a major thing but due to having a motor that now has a bit of dirt on it you can tell the small leak is coming from the water pipe #10 under bolt number #19 and slowly dripping down and wresting on the water pump cover. I am wondering if I should just buy the washer o-ring number # 31 and try to replace it with a new one.
2013 Honda CBR250R OEM Right Crankcase Cover | MotoSport
The leak is small but I have more long distance miles to rack up this summer.
I have been staying on top of the leak via the overflow tank and yes the bolt has already been tighten down.
If any one knows what the proper tq specs for this bolt is I would be thankful to you for your input.
Old 04-14-2013, 12:40 PM   #7
Originally Posted by 7point62fmj View Post
... I am wondering if I should just buy the washer o-ring number # 31 and try to replace it with a new one...
I would... I'd replace both o-rings for the coolant pipe.
... If any one knows what the proper tq specs for this bolt is I would be thankful to you for your input.
Honda doesn't call out the torque spec for that specific bolt, however they list the standard torque value for the 6 mm flange bolt (8 mm head, large flange) as 12 N-m (1.2 kgf-m; 9 lbf-ft). Just like the oil filter cover bolts, easy does it when tightening them. I wouldn't even use a torque wrench on these bolts, unless you have a very good quality 1/4" drive unit that is accurate. Otherwise finger tight, then a bit more with a wrench should do it.
At any given moment in America, 100,000 idiots are texting while driving... it's the new drunk driving.
7point62fmj (04-14-2013)
Old 04-14-2013, 06:21 PM   #8
I wonder how full this line is when the motor is dead cold. I dont have my bike in front of me right now to trace the cooling sequence. It only leaks when the motor is warmed up.
Old 04-14-2013, 07:29 PM   #9
The entire cooling system is full with coolant. You'll have to drain it as much as you can before removing that tube, otherwise you'll just end up with coolant all over the place. I think the place to start for draining it would be the right side radiator hose, where it attaches to the water pump... you should be able to recover most of the coolant into a clean container by draining it there.
Old 04-15-2013, 05:30 AM   #10
The lowest bolt in the water pump housing is designed as a drain bolt for the system and has a sealing washer for that reason. When refilling make sure the air is bled from the system. ( Basically fill to the top of the radiator cap, run for a few minutes and rev the engine a few times, top up the radiator and fit the cap. Top up the reservoir to the full line.)
I agree with the comments about not over tightening the bolts. Getting them tightened evenly is more important. Honda don't specify using any sealant on the rubber 'o' ring type gasket my personal preference is a bit of rubber grease spray but that just to help it seat evenly.
Regards Roadster
roadster is offline
