engine "skipping"? - Page 2 - Honda CBR250R Forum : Honda CBR 250 Forums
Old 11-22-2012, 03:25 AM   #11
If all is OK with clutch freeplay and rear shock, it could be the oil that looses friction and causes sudden slip at high power, suggest an easy check by making a change to an oil claiming JASO MA2 (MA2 has higher friction than MA1) . When only JASO MA is on the can one can't tell if it would meet MA2, so avoid that in this case.
Richard
CBR250R as my 1st bike
GoRide is offline
The Following 2 Users Say Thank You to GoRide For This Useful Post:
shisoshin (11-22-2012), UnMonk (11-22-2012)
Old 11-22-2012, 03:27 AM   #12
Wynne G Oldman's Avatar
Yes, as said before really. Check clutch ajustment and make sure you're using motorcycle oil, not car oil.
Wynne G Oldman is online now
The Following 3 Users Say Thank You to Wynne G Oldman For This Useful Post:
MotoMike (11-22-2012), shisoshin (11-22-2012), UnMonk (11-22-2012)
Old 11-22-2012, 12:56 PM   #13
The engine speed up (without the bike speeding up) in the high gears is the normal indication of clutch slippage/excessive clutch wear.
Nekid motorcycles feel faster
jsonder is online now
The Following 2 Users Say Thank You to jsonder For This Useful Post:
Old 11-22-2012, 02:19 PM   #14
I believe it is clutch slippage, the lever its self is very loose.
What do I do to correct?
Is it because of my driving habits?
UnMonk is online now
Old 11-22-2012, 03:16 PM   #15
our clutches are 'wet' ie, immersed in oil..
oil condition will effect friction to some extent
regardless,, whether or not that underlies your slipping
events isnt certain here, but at 8krpm engine is close to
its high hp/torque range, so...
members have pointed out the most likely first options
so firstly adjust your activating mechanism, the clutch lever
itself both ends plus general checking of cable etc [who knows]..
second would be replacing the old [you mentioned time since changing]
oil, as advised by richard above, or some similarly appropriate oil..
[given appropriate oil, it can only cost in $ anyway]
ive never had a clutch problem in 4 previous road hondas
so doubt this nicely designed honda engine would fail here
so early.. adjustment is free, oil is necessary..
if they dont correct it best use a honda mechanic..
Old 11-22-2012, 05:54 PM   #16
Do you slip the clutch a lot? At high rpm? Do you ride around with your hand resting on the clutch with a little pressure on it? These things will eventually damage the clutch. Just like in a car...
Make sure your hand is nowhere near the clutch when riding would be a good thing to do in your case as a check that its not your habit to actually be putting pressure on the clutch. If you put some pressure on the lever you may be reducing the pressure on the clutch plates: then the clutch will slip. This doesn't need a lot of pressure to happen, especially if you have no freeplay. Even a slight bump in the raod could cause you to put a wee bit more pressure on the lever = slip of clutch "randomly".
Your OP says you are still on the original oil...if the oil is very old then it will not be able to do its job properly. How many km have you done on this original oil? It should have been changed out at 1000km/600miles.
What do you mean by the "lever is very loose". Is it loose and then gets harder to pull after about 10mm? The first "loose" 10mm is the freeplay. I ask as the CBR has a very light clutch, and so you think it is "loose", when it might not be and so you have no freeplay in actuality.
1. Check your riding habits. No hand on the lever when not changing.
2. Check the free play properly (RTFM)
3. Change the oil
3. If the above don't solve it, then go to your dealer.
Dave
Eleven hours in a tin can?
CBR_Dave is online now
Old 11-22-2012, 06:41 PM   #17
Have you got handlebar muffs on your bike? These can sometimes make your clutch slip at high speeds, as air pushes against them, and the clutch lever.
Old 11-22-2012, 09:04 PM   #18
I do abuse the clutch a lot while riding, something I will have to work on I guess.
By loose I mean the clutch can almost engage just from a gust of wind. I need to check the screw or something.
I am on the oil change after the 600m service, but am almost to 4000 miles, so Ill probably be swapping it out soon.
Old 11-22-2012, 10:40 PM   #19
Ohhh...wow, this has been a waste of time then. You know you abuse the clutch and that a puff of wind affects the clutch.... Both things are pretty obviously going to cause an issue.
Take it in to your dealer: I don't think you should be touching your bike .
BTW: I think you mean dis-engage. Pulling the lever towards you *dis*-engages the clutch as it separates the plates. When a clutch is engaged the engine can drive the drive chain.
Old 11-22-2012, 10:42 PM   #20
I suggest that you RTFM .
Dave
