As you are going into your summer season, it shouldn't hurt, as long as the oil filter was installed properly.
The color comes from incomplete drainage. I tend to stand my bikes on their kickstand and rotate them so that the oil drain hole is as close to on the bottom as I can safely support. I still cannot drain all of the old oil from the CB500XA.
Yes. I was pretty paranoid after reading the "engine destruction thread", i took pictures of the old one which depicted the extruding black seal on the filter should point towards the engine. (opposite side of the spring)
I had it on the paddoc stand for a good 10 minutes after riding for about that long to heat the oil up. *shurgs* dunno what else i coulda done. I did rock it abit, but ill try rolling it abit more next time like you said.
its really black tho? the oil usually had a honey yellow color never this black
I've never been able to get all the old oil out, and my fresh change generally turns a nice brown after I've ridden it. But diesel oil is also generally a bit darker than automotive oil, and turns a darker shade a bit faster from what I've gathered.
I'm sure your perfectly fine. What you can do if you ever want to and kill time is buy 3 of everything you can change your oil 3 times. I've done that and it's golden.
#1 thing to check is to make sure you're reading the oil level in the sight glass correctly and you didn't overfill it.
Hey, has anyone here ever tried using a vacuum syphon to extract their old oil instead of draining it?
I use a LiquiVac to change the oil on my Altima Coupe. It works great and it seems to actually get more of the used oil out than when I was draining it into a pan.
