Originally Posted by Aufitt
30mm is a tad on the tight side, 35mm minimum is better to avoid stretching.
Loose= good
tight= bad.
Cool, but the manual says 20-30mm?? But I recall you saying 30-35mm recently.
In any case, I think 30mm is on the low side in my case as it had it in gear...
EDIT: I just checked and its 30mm in neutral - although I have not checked it the whole way around, but it seems pretty consistent from what I have checked.
Dave
