Running in procedure. - Honda CBR250R Forum : Honda CBR 250 Forums
» Sponsors
Old 12-25-2012, 05:26 AM   #1
Member
Default Running in procedure.
As my bike will be delivered next week thought I'd ask about the running in procedure. What is the "Official" Honda way and are there any tips on doing this properly. I really want to get the best from this bike.
Thanks.
David.
djsb is online now
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 12-25-2012, 05:39 AM   #2
Super Moderator
lewiCBR250R's Avatar
Default
As per honda manual
File Type: png Screen Shot 2012-12-25 at 9.05.34 PM.png (27.9 KB, 45 views)
__________________
2012 CBR250R ABS Red/Silver
- Black Adjustable Levers
- HRC Carbon Fibre Tank Pad
- Hotbodies FE Kit
- 16,000km's in 12 months
lewiCBR250R is online now
Old 12-25-2012, 05:45 AM   #3
Super Moderator
Default
just vary the revs, don't stay at one rev for too long, do what it says in the previous post and just don't redline the bike, i kept mine below 7,000rpm and just went a bit easy.
Some people break their bikes in on the track, some believe riding it like you stole it is a good technique, there is really no right or wrong way of running it in and there are many methods. By the way, honda runs the bikes through all the gears and takes it to redline from the factory before you get to ride it so they even ride it hard to make sure everything works ok
Skip to 3:30
__________________
- Hotbodies FE Kit
Old 12-25-2012, 08:58 AM   #4
Aufitt's Avatar
Default
The factory has run it on rollers to redline.
The dealer will start bike up after the battery charge and let it cool down.
Dealer should have ridden the bike around the block 1.5km and let cool down.
Go to dealer warm up to 3 bars on the temp guage with constant blips of the throttle, let bike cool down while you sign your life away on the purchase contract.
Ride home 1/2 throttle 1/2 revs (6000rpm), let it cool down while you memorise the entitre owners manual.
later that arvo after you've lubed & adjusted cables, adjusted pegs, lubed lever pivot pins, set the shock sag, lubed gear shifter pivot pin, checked tyre pressures, lubed chain, etc go for ride 15-20km 3/4 throttle, 3/4 revs (8000rpm), 3/4 load, let bike cool down.
Next day ride bike half hr to 1hr, 50-100km distance working every gear up and down @ full throttle full revs (10,500), let it cool down.
When you get home drop the oil & change filter, with battery disconmnected while you do so.
bike is run in and ready to be flogged the ******************** out of untill the first sevice when the valve clearances will be checked and the oil & filter changed again.
It will never rattle or stall, & wont need shims @1000km and produce its optimum power for the next 100,000km.
^or ignore all that and book in for a dyno run and its done in 1/4 the time.
__________________
Team Gumby.
Aufitt is offline
Old 12-25-2012, 11:17 AM   #5
Soulbreeze's Avatar
Default
Haven't heard of anyone having issues regardless of how any particular bike is broken in.
But if you go for a hard break-in, change the oil a couple of times before the first service.
Biggest thing is they want the bike to go through hot and cold cycles. So ride it so it gets all warmed up, park to cool down. Then get it hot again, then park it. Keep rpm variable and that's the general break in for any bike I've ever heard of. Only thing is to not hold constant speeds as this makes the rings wear-in incorrectly and not give the best seals (just from what I've read).
Soulbreeze is online now
Old 12-26-2012, 03:25 PM   #6
Rory_L's Avatar
Default
My dealer simply told me to keep it under 6000 rpm until the first service (600 miles).
__________________
. . . It's pointless to race between Starbucks', around here they are 300 yards apart!
Rory_L is online now
Old 12-26-2012, 05:41 PM   #7
Joeboo's Avatar
Garage
Default
I've had bikes, outboards, cars etc & gone by the take it easy approach & they just don't rev or perform as well as the ones I've given a real hard time to. Once it's warm I take it to just before redline & vary the revs but never let it lug. Another thing I don't do is free rev it, it's not good for an engine without load on it. All our drag & race car engines are built, tuned & run hard, some even last a season. Warm it up & ride it, worst case it's got warranty
Joeboo is online now
The Following User Says Thank You to Joeboo For This Useful Post:
SDM (12-27-2012)
Old 12-26-2012, 05:52 PM   #8
sac
Default
arvo
Web definitions
afternoon.en.wiktionary.org/wiki/arvo
sac is offline
Old 12-27-2012, 08:48 AM   #9
SDM
SDM's Avatar
Default
Every motor I break in the same way, ride it, drive it like I stole it, never had a problem just change the oil & filter keep up with your maintenance.
__________________
Custom Painted 2012 NON ABS
Steel braided brake lines
CORBIN front and pillion seat
Pirelli Diablo tires 150/60/17 rear
110/70/17 front
HID Projector
DFC fuel controller
2 Bros slip on
Lots of Bikers products
In the garage...
2013 Mits Lancer EX/GTA Onyx Black
2005 Honda CBR1000RR repsol edition
http://www.cbr250.net/forum/cbr250-a...od-thread.html
SDM is offline
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
