Speedometer going up and down , bike dies. - Honda CBR250R Forum : Honda CBR 250 Forums
 1Likes
  • 1 Post By jkv357
post #1 of 4 Old 07-13-2018, 11:41 AM Thread Starter
Hey out there, my 2011 cbr250, dies intermittently , at about 3rd gear or so , it'll seem as if its sluggish then , speedo would jump from 30 to 60 then to 90 then dies. Any Suggestions Out there...Thanks in advance.
Cgray is offline
post #2 of 4 Old 07-13-2018, 06:38 PM
Copied to Problems and Issues; look for the answers there.
jsonder is offline
post #3 of 4 Old 07-14-2018, 02:11 PM
Could be an ECU problem; ECU doesn't use speed in calculating timing curves to my knowledge, so I don't think a speed sensor problem would cause your bike to stall. But, could also be a bad ground leading to the ECU that is also in the speed sensor bundle. Check all wiring and connections first.
post #4 of 4 Old 07-14-2018, 05:21 PM
First thing I would look at is the battery voltage. Check it before starting. It should be 12.7V or more.
If that's fine, check all of the battery terminal connections, ground connection to the frame, and eventually main connectors (for corrosion) and fuses for poor connections.
Schroeder likes this.
You may post new threads
You may post replies
