Chain length - Page 2 - Honda CBR250R Forum : Honda CBR 250 Forums
 4Likes
post #11 of 18 Old 12-16-2015, 12:16 AM
OzHonda's Avatar
Send a message via Skype™ to OzHonda
Originally Posted by kiwi rider View Post
I'm going to fit a non-O'ring chain. which has less rolling resistance.
Not rocket science but an interesting mod all the same.
More maintenance though. That is the benefit of o/x/z ring changes. Less maintenance. Couldn't imagine having a non o-ring for my commuter.
CBR-250-R likes this.
YouTube:
Current: 2003 CBR600RR
Sold:
Ride carefully - You are invisible.
Mods:
Feb, 2014 Photo of the month winner
OzHonda is offline
post #12 of 18 Old 12-16-2015, 02:32 AM
Yep, I agree, those chains are a great invention. However I don't commute, mainly sports riding and I was doing track days on it.
I was at the race track the other weekend and there was a guy there racing a Ninja 300, full on track bike, all the fruit etc.
He had a thin side plate, non-Oring chain on it that was so slim line I mistook it for a 428 conversion kit at first. He had it up on a paddock stand and spun the rear wheel for me. Well, it just kept going and going and going like the energizer bunny. Impressive.
I already have the chain in my garage so may as well bang it on, but sure it will require more regular tightening probably and wont last as long. Like most things, there's always trade offs.
2013 CBR250R repsol (sold)
2014 CBR300R (sold)
2007 SV650 (track bike)
2004 XR250R (dirt bike)
2018 Ninja 400
kiwi rider is online now
post #13 of 18 Old 01-05-2016, 04:39 AM
CBR-250-R's Avatar
I didn't take links out of my chain because it was the original endless one and I wanted to keep it that way. ....
I got a 300R OEM chainset, today, for my 250R.
And I think, the chain-lenght is not really of concern.
Minimum for the first 10-15.000 km.
Here a picture to guess the diameter change compared to a 38T, that comes on top of the 36T's 2 links less on the sprocket
Disclaimer:
CBR-250-R is offline
post #14 of 18 Old 01-05-2016, 11:03 AM Thread Starter
lemmy99's Avatar
Hey Lemmy, I ride a 300R and can tell you it has a 108 link chain standard. Ive dropped one tooth on my sprockets from standard and at 8K miles on the clock I'm nearly out of adjustment.
This is properly the answer I was looking for, if ordering a 14/36 set I would opt for the 106 chain length to allow for an optional 13T front without running out of adjustment.
2013 CBR250RAD Repsol Replica with ABS (now sold)
Presently have a 2002 Ducati 750Sport ie
lemmy99 is offline
post #15 of 18 Old 01-05-2016, 12:07 PM
CBR-250-R's Avatar
Wink
For the 13/36 (custom), you need for 108 links (Check on gearingcommander.com ) just 4mm more! (to 14/36-108)
But with the 14/36 (current) but 106 links, you need almost 1 cm space, to the front. Direct after assembling it.
You have one more cm, from a new 108 link 14/38 combination, to the front?
I still have in mind, that I'll have to cut of 2 links in about 15000km . Maybe.
But till then, I do not see a problem with 14/36 and 108 links.
Ok, I just start seeing one:
108 links, 36 t = every chain link hit always the very same tooth on the rear sprocket
Now I remember, why I was usually looking for a 37t sprocket in steel.
Couldn't find one, all aluminium.
So106 links would be better!
But only 26 hp and a 520 chain
ok, will report later
Disclaimer:
post #16 of 18 Old 07-06-2016, 07:34 AM Thread Starter
lemmy99's Avatar
Just to finish off this thread
Bought a new (CBR300) 14/36 combination, runs ok but not quite my style, so changed to 13/36 which is just under standard +2% and it works for me.
Pic below are for the 13/36 on 108 link chain (no adjustment left at all) and after I removed I link pair and fitted an VX heavy duty master link. (106 link chain).
Cant upload any pics at the moment, just lets say, 13/36 on 108 link chain is a max adjustment and 13/36 on 106 link chain is at minimum adjustment
lemmy99 is offline
post #17 of 18 Old 07-06-2016, 09:28 AM
Assuming you meant a 36 tooth rear (you wrote 46)?
Setting aside the chain length issue, and comparing the ratios of these sprocket combinations, there isn't much of a difference in final drive ratio after changing to the 13/36...
13/36 = 2.769
14/38 = 2.714 (stock)
Not much of a net change... dropping one tooth on the front and two on the rear basically cancelled each other out.
post #18 of 18 Old 07-06-2016, 04:23 PM Thread Starter
lemmy99's Avatar
Mike,
I wanted to see what the 14/36 CBR300 was like, to tall for me personally and 13/38 was too low when i tried it last year, so i was left with with an as new 13T front after i returned the gearing to stock.
When the chain set wore out and i had to cut out a link from the std chain to gain some adjustment it was time for some new parts.
I managed to score a brand new endless 108 chain and 36T rear from a 0 mile breaker on ebay for 35 and a 14T front for 9.95. ( a full DID O-rng set n the uk is 98.0)
I tried the 14/36 and then went to the 13/36 as a compromise, i now have a as new 14T front in stock for the change back to 14/38 in 9-10 thousand miles time when the 13/36 wears out.
lemmy99 is offline
