Problems with battery draining. - Page 3 - Honda CBR250R Forum : Honda CBR 250 Forums
post #21 of 30 Old 03-25-2013, 08:39 PM
Voltage drops during the starts is indeed normal, but once running the voltage should stay above 14 volts. I doubt that fuses have anything to do with the alternator issue you describe, unless the wiring has been tampered with. If the voltage drops to battery level when you rev it the alternator / regulator is cutting out and faulty. This may well be under warranty, but I would still install a new and charged battery for the few dollars it will cost before spending money on repairs.
Good luck.
Rick
Island Rick is offline
post #22 of 30 Old 03-25-2013, 10:28 PM Thread Starter
atakacs's Avatar
Re: Problems with battery draining.
My bike is less than a year old. Would Honda cover this under warranty... especially since I added some aftermarket lighting?
2012 CBR250RA all black w/ ABS, blackened muffler heat guard, P3 brake flashers TS+.
Green: reflective rim decals, LED lighting, custom "to punish and enslave..." lettering.
Riding gear: Icon Contra Mil-Spec Hi-Viz & HJC CL-16 helmet
Planned: Upgrade to 2017 FZ-09 w/ ABS
My MPG via fuelly:
atakacs is offline
post #23 of 30 Old 03-26-2013, 06:36 AM
Won't cost anything to ask your dealer if this is covered.
post #24 of 30 Old 03-26-2013, 08:04 PM Thread Starter
atakacs's Avatar
I asked the service Rep @ a local dealership today if the warranty would cover it and he said it should & he would do his best to cover everything under warranty. I'm dropping it off Thursday and probably picking it up Friday. I'll keep you up to date. In the meantime, I've been parking the bike on the other side of the complex so as to avoid pushing it uphill to clutch start it.
My MPG via fuelly:
atakacs is offline
post #25 of 30 Old 03-28-2013, 10:58 PM Thread Starter
atakacs's Avatar
Took it to the shop & they said the system was charging fine & then load tested the battery & said it was bad. I rep mm aced the battery & installed a battery tender. Let's hope that solves it. Oh and they said that it wasnt covered under warranty since it was only the battery.
My MPG via fuelly:
atakacs is offline
post #26 of 30 Old 04-01-2013, 03:57 AM
roberthood's Avatar
They didn't replace your battery? That's a load of crap! If you already hooked up your Tender, I'm sure by now you know how to read the lights. So is it charging up?
It's not about how much power you have, it's about how much you can actually use.
roberthood is offline
post #27 of 30 Old 04-02-2013, 09:38 PM Thread Starter
atakacs's Avatar
It's been several days since last ridden last friday. It started right up and it wasnt on the tender at all. Seems like it was the battery after all.
My MPG via fuelly:
atakacs is offline
post #28 of 30 Old 04-09-2013, 09:57 PM
Giko's Avatar
I'm glad you fixed it. Try not to drain it again
Giko is offline
post #29 of 30 Old 05-19-2013, 09:44 AM Thread Starter
atakacs's Avatar
It's been almost 2 months and I've had no problems since replacing the battery.
The stock battery lasted 7 months before giving me problems. I can think of 2 things that contributed to a bad battery. I ran the battery down once while testing the wiring on a fender eliminator & I had to charge it up using a battery tender. During that time, I had a short that I found & resolved after it wouldn't start with 3 hours of charging.
It was ok though until I shipped the bike and it remained in storage for about 2 weeks. I'm not sure if the movers hit my underglow button & left it on or what but from the time I received it, the battery wouldn't hold much charge.
I think the moral of the story is dont let your battery run down.
My MPG via fuelly:
atakacs is offline
post #30 of 30 Old 05-19-2013, 05:24 PM
You are indeed correct about keeping the battery charged. You do not have to be
a fanatic about it , it can sit idle for some time if there is no outside drain, but starting batteries especially (as compared to deep cycle batteries) do not like to be drained, and if drained recharge as soon as possible because there will be permanent damage. Luckily new batteries can be relatively cheap. Amazon will sell you a new Chrome brand 7AH battery for about $30 shipped.
The Following User Says Thank You to Island Rick For This Useful Post:
atakacs (05-19-2013)
