Clutch Cable Friction... Clean & Lube? - Page 5 - Honda CBR250R Forum : Honda CBR 250 Forums
 6Likes
post #41 of 44 Old 06-16-2017, 02:50 AM
Originally Posted by Stichill View Post
If you can get Motion Pro Cable Lube, it works very well for routine maintenance. Lubrication before installation may not be necessary but it certainly cannot hurt.
Hey Stichill, I've looked every where here in South Africa with no luck.
I'll use what I currently have and set a reminder to do it ever 3 months or so as it is such a quick thing to do.
Sent from my SM-N910H using Tapatalk
My Fuel Economy by
Mufasa is offline
post #42 of 44 Old 06-16-2017, 12:27 PM
Hey guys just spend an hour or so replacing the clutch cable.
I also decided that I will take both clutch and brake levers off to regrease the pivot points and polish the levers to a shine.
They feel brand new. I've also put a reminder for every 6 months.
I've attached a picture of my old cable. It had 3 solid strands left.
Any way good day and ride safe.
dilop likes this.
My Fuel Economy by
Mufasa is offline
post #43 of 44 Old 06-16-2017, 03:45 PM
Mufasa, this isn't very elegant or high tech, but, I use a dropping bottle (old eyedrops or nasal spray bottle will work) with automatic transmission fluid and add it a drop at a time to the cable below the barrel but above the cover (sheese, that is the only place that you can lube the clutch cable). I add a dab of grease to the hole in the clutch lever before re-installing the barrel, also.
shisoshin and Mufasa like this.
jsonder is online now
post #44 of 44 Old 06-16-2017, 10:28 PM
similar with cable tied in a U shape, sewing machine oil by the drop..
wait, sm oil penetrates, drain [re-use].. or just sm oil into vertical cable..
[mothers] sewing machine oil worked well tho, thus this habit...
Mufasa likes this.
