1 - 2 of 2 Posts
hi guys. New here.
I have a 2011 cbr250r front end (triple clamps, forks, wheel etc) with abs calliper that I'm retro fitting to a 1979 kawasaki z250a.
What i want to know is how I can run the abs calliper with out the abs system. I have the abs calliper and the two brake lines that go into a block?. And that is all? I was hoping it may be as simple as 1 into 2 type set up or even running a double banjo. The other option is to block off the centre piston, but which line is that one? And just run the main 2 with a single line?
Also not sure what master ill be using yet.
Any help and feed back would be appreciated.
Thanks.
Hi Wade and welcome to the forum.
I'm not sure if this helps and you probably know all that stuff already but the front caliper should actually have three lines. Two brake lines and one cable for the ABS sensor. The ABS version of the CBR has a linked braking system that connects the rear brake to the front (when the rear brake is engaged one of the three front brake pistons is activated also). So there is one brake line from the front brake, a second one from the rear brake and the ABS sensor cable.
I'm sorry if that wasn't helpful but I'm not much of a tinkerer.
1 - 2 of 2 Posts
