You have to also swap over:
- wiring harness
- ECU
- all sensors
- anything and everything attached to engine
Did you do this?I take it you also swapped over ignition switch? It’s matched to ECU
Still no go?Yeah so you know him too and yeah I did
You know, that's good point. I made this mistake one time many decades ago. Guess where power to starter will get its ground? Through any other earthing point! That means through harness wires and it'll fry them!It may seem too simple, but is the earth lead from the battery actually connected back to the motor? Also, have you teat d for battery voltage at various connectors along the wiring loom?
