1 - 4 of 4 Posts
Hay guys my honda is giving me some trouble if I drive low reves it's all fine but as soon as I give it Gass the engine light just keeps flickering like crazy and the speedo also goes nuts like it shows I'm driving 70/100/40/60 the the bike just deis, when I start it again the engine light flashes like mad again after a minute or two it starts again and only a few km's and everything happens all over again
Check your battery. Chances are it's an electrical issue.
Check the battery voltage, but also check the terminals to make sure they are clean and tight.
If the battery and connections check out fine, check all the fuses and fuse block for corroded contacts.
1 - 4 of 4 Posts
