1 - 8 of 8 Posts
Google translate from Turkish to English:
"If the motorcycle does not run on the side stand, it runs smoothly when you sit on it and start. Could the fuel filter be clogged?"
Welcome to the forum. Sorry, I'm not sure I understood your question.
(1). If the side stand is open then you can start the engine provided the gear is in neutral gear.
Reactions: DannoXYZ
(2). If the engine is running and is in gear 1 to 6 (not in neutral), if in such a situation you stop and lower the side stand, then the engine will turn off.
(yildizbeyhan please, if it's not difficult for you, write here in English. thanks)
"Does not work on the side stand, works smoothly in the upright position"
yildizbeyhan If you are in gear, then everything is OK.
Lowering a side stand with a shifter in gear 1 to 6, engine-on, causes the engine to cut off.
1 - 8 of 8 Posts
