OK stupid question. Whats a juice box?
Hope not, have been posted on their website for a month at least.I just talked to someone in tech support at 2 Bros and was told that it will be a couple more weeks before they're released. "Still in testing right now...."
Reset will no longer do anything with any piggyback fuel box. First thing you do upon installation is disconnect the O2 sensor which will lock the stock computer to a fixed mode where the fuel box can modify the stock maps from there.Just purchased Juice Box Pro from 2Bros, am assuming this will require an ECU reset once installed. Have seen the you tube videos and read threads on the process, any addition info would be helpful, on either the install itself or the ECU reset.
I've got a sneaky hunch that there's not a whole lot of difference between different manufacturers' products for the average street rider from the standpoint of fuel maps. For instance, a map that will work fine on a 2-Bros with insert will probably work just as well for others that also have an insert.When I read about it though, it says that the custom maps are designed to each different 2 Bros exhaust. In the end though, if you're using a non-2 Bros exhaust, you will still have to do some tuning yourself (that's what it seems like to me anyhow)..
But then there is also no listing for the CBR250 unit itself. I'll bet that the downloads will show up when the testing is finished and the units get shipped.Also, on their downloads page, there are no custom built maps yet for the CBR250R yet.
OK thanks I have heard of a power commander but not a juice box. One and the sameLike a Power Commander, piggy back fuel controller.
your first point is well made, I chose the 2Bros because I have their slip-on installed and also like the ability to change maps without plugging into PC.I've got a sneaky hunch that there's not a whole lot of difference between different manufacturers' products for the average street rider from the standpoint of fuel maps. For instance, a map that will work fine on a 2-Bros with insert will probably work just as well for others that also have an insert.
thanks for the info dude. Disconnecting the O2 sensor to lock the ECU in place seems commons sense, now you've mentioned it.Reset will no longer do anything with any piggyback fuel box. First thing you do upon installation is disconnect the O2 sensor which will lock the stock computer to a fixed mode where the fuel box can modify the stock maps from there.
To be honest dude, I don't really know. First time I've done this sort of mod, so it will be a bit of a steep learning curve to start with. Which is why I stuck to same brand as my exhaust and a simple "plug in and ride" system with pre-made maps from manufacturer. Once I get used to it and read some more about fuel mapping will give it a go myself a little bit at a time.Looking forward to feedback once it's all up and running.
Will you be able to change the powerband with the J/B? So the power doesn't peter out at 9k rpm but keeps going until 11k?
Help a noob out here.Umm i'm pretty sure you saw it on Thaivisa when i posted it..but for the rest.
