I can see what youre saying about it throwing off the AFR readings, but Im curious how it stops the popping and why its recommended to remove it when installing an aftermarket exhaust/fuel controller if there are no performance gains. Not trying to be argumentative or anything like that. I am genuinely curious, is all.
Thanks for the great info on this subject! Maybe we could take the posts about the PAIR valve out of this thread to keep it on subject and create a stickied thread for discussing the PAIR system?
Admins? Yay/Nay?
This will take a little while and corrections, disagreements, or criticisms will be welcomed.
The catalytic converter on motorcycles are generally a hard porous cylindrical devise that the exhaust heats up as it goes thru. The unburnt gas in the exhaust is wicked up in the cat and the heat in the cat creates a sizzling burn off rather than an explosion.
The pair valve injects fresh air into the exhaust to bring the rich unburnt gas closer to the 15 to 1 combustion ratio so it ignites easier when it goes into the cat. They do work quite well and with very little backfiring.
To block off the pair valve with the stock muffler still on makes no sense to me.
Nothing is gained.
To not block the pair valve and run an aftermarket muffler with no cat just introduces unburnt exhaust into the muffler that is ready to ignite and backfire.
To block the pair valve and run an aftermarket muffler will minimize the chance of backfiring because the unburnt gas will still be to rich to ignite and just pass thru.
It is more of a situation of not, that blocking the pair valve prevents popping and backfires, as that by leaving it active it creates the perfect possibility for popping and backfires to happen.
The only real world benefit of disabling the pair valve with an after market muffler is that the muffler wouldn't have to be repacked as often.
All in all it's not really that big of a deal. Sometimes a burble, a pop, and a backfire is fun to hear.
