1 - 16 of 16 Posts
Just wondering if anyone has experience measuring sound of a bike, let's say a cbr250r at 10k rpm... :)
Will it be near 96 decibels?
That is the new limit here, coming into affect Aug.1 -$200 fine
If you have an iPhone this app is accurate and free.
Sent from my crackPhone using MO cræsh Free
Just tried it. Registering 40db in dead silence in my garage.
50db outside with the highway traffic 1.5 miles away.
80db with bike at idle, 95 db @5k RPM ( in well insulated garage)
Doesn't seem right but will see if I can test it on the streets.
Most certainly not with the stock exhaust.
Is that the level for bikes manufactured after August 1, or does everyone have to modify their existing bikes to meet the new requirements? Sounds a bit retarded to me, and if it is indeed the latter, a sneaky means of generating a lot of revenue in the first few weeks of August.
Discussion Starter · #8 ·
Yip, new local bylaw. Affects any vehicle driven on the road.
I will have to see if the specify distance but it would be simply on the side of the road where the police would be setting up.
Certainly a lot of HD's around here that will get nailed.
I know my stock bike is not exactly quiet compared to minivans and cars when driven as designed
Still would like to know where "here" is. And there is no way a stock set-up exceeds this limit. The town I live in, Whitehouse TX, passed a noise ordinance without setting any limits or protocals to test it. Basically, if some one complains, you get a ticket. I've been to every city council meeting since trying to correct this nonsense. TX.
A 10 db increase is close to triple the loudness.
Exactly. Every 3 dB increase is roughly double the loudness.
FWIW, a whisper is about 20 dB. 40 dB would be over 6.5 times louder than a whisper. Normal conversation is about 60 dB, which is another ~6.5 times louder than the 40 dB rating.
Doesn't sound that far off to me, actually, if the ambient noise in the garage was somewhere between a whisper and normal conversation. Never been in his garage, so I can't tell you...
But then again, the microphone in an iPhone is not the most discriminating and sensitive device either... I'd say the app can give you an IDEA, but not a definitive scientific result.
Calibration must be of due to sensitivity. I borrowed my bro's decibel meter and its coming up as 20db outside in silence. be it that i live next to the highway its not a "dead silence" so to speak but then you have wind noise, birds, etc. Be willing to accept that your not in a control environment so your readings wont be accurate to a certain degree. And when you guys are measuring the sound i hope you're doing it at the proper distance from your pipe. CT's ordinance is 94.8db at a distance of 50ft. Which makes sense because I haven't been pulled over by the police even when they're right next to me (knocks on wood).
My reading at 50ft w/ MGP Growler slip on and drilled airbox cover
57.3db - 59.1db at idle (1500 rpms)
82.9db - 86.7db at 5500 rpms
Any higher rpms and my pipe becomes obnoxious.
hope this info helps
1 - 16 of 16 Posts
