The brake fluid on a CBR250R Combined ABS model has to be changed / bled in a different way as on a non ABS model! It is not enough to do it the common way, only just by pumping.A couple of questions -
1. Are the front and rear brake systems linked on an ABS CBR250?
2. What is the procedure for bleeding the ABS brake system?
last I checked your post is linking to another persons oil change instructions and asking the exact same question as this thread, so please tell us, why should we look at your thread?The brake fluid on a CBR250R Combined ABS model has to be changed / bled in a different way as on a non ABS model! It is not enough to do it the common way, only just by pumping.
Take a look at my thread, please:
http://www.cbr250.net/forum/cbr250-...luid-cbr250ra-cbr250r-combined-abs-model.html
As you can see: two questions and unfortunately no answer yet. I think not many of us had done this work until now. You are welcome to start, if you have the possibility to do it, unstead of writing attackable comments. I am planning to change the brake fluid when the temperature will rise, now it’s too cold in my place for working outside on a motorcycle.last I checked your post is linking to another persons oil change instructions and asking the exact same question as this thread, so please tell us, why should we look at your thread?
it's useless.
Where are you getting this idea?The brake fluid on a CBR250R Combined ABS model has to be changed / bled in a different way as on a non ABS model!
There must be brake fluid in the ABS valve unit, so you have to open the valves and pump out the fluid, which is inside the unit.Where are you getting this idea?
