Abs model Lock set problem
60 Views 1 Reply 2 Participants Last post by  Tamir
I have a abs variant 250 it had key issues so i that of replacing it with a lock which comes for non abs variant but it has only 2 pins but the older one(2011) had 3 pins how will i make it work for me
Can anyone help me out!
1 - 2 of 2 Posts
2
Hi, and welcome to the forum.
Your problem does not correspond to the model on with OR without ABS.
Your problem is related to the subject of "the pink wire, and a zener diode".
This is anti-theft wiring that does not appear in the OEM wiring diagram.
With the right wire, the pink wire gets 9V.
It is possible to give the pink wire a voltage of 9 volts with a battery of 9V.
Gesture Font Line Parallel Elbow
Liquid Fluid Drink Cylinder Font
1 - 2 of 2 Posts
