1 - 5 of 5 Posts
Question:
If i were to mount an external 12 volt 24 LED brake light wired up straight to the brake light wiring, would the original brake light be dim if an additional light is hooked on? or will it be fine?
Or would i need a relay and take power from the battery?
I think my Knight Riderz sequential aux brake light is 12 High Power LEDs and only draws like 1.5-2 watts max..will not phase your brake light bulb in the least ..just tap right into the power and ground wires in the tail end underneath.
my 900 lumens denali D2 driving lights draw a paltry 10 watts apiece and dont even phase the output of the alternator...consider that regular halogen or xenon driving lights are normally at least 50 watts per light
1 - 5 of 5 Posts
