This akrapovic is the first one in India for Honda Cbr250r.
Content Not Found | Facebook
Any pipe without sufficient backpressure will ultimately reduce engine life.After installing akrapovic carbon slip-on,does it effects engine life?![]()
I recommend getting the bolt on exhaust only because if you go with a full system (headers and all) you are going to alter your air/fuel ratio, then you would need to buy something like a Bazzaz ZFI tuning system to regulate the new fuel ratios.Guyz i'm gonna buy akrapovic for my baby blade,should i go with Just the exhaust or with header set?
The truth about exhaust backpressure and torqueAny pipe without sufficient backpressure will ultimately reduce engine life.
Yes I should have said 'without tuning'The truth about exhaust backpressure and torque
Backpressure is universally bad in a fuel injected engine, unless a chimp created the fuel map for your megasquirt.
