1 - 1 of 1 Posts
· Premium Member
Nobody likes to get caught in the rain while riding, but it’s bound to happen to everyone at some point. Be prepared with the new Quick Seal Out 2PC Rainsuit from Alpinestars.
The whole suit is constructed from 100% waterproof material with taped seams to keep moisture from seeping in. The material is breathable as well, so you don’t have to worry about encountering the sauna effect caused by some rain gear when moisture/sweat builds up underneath the waterproof layer with nowhere to go. Instead of a hood, the jacket features a higher profile collar for more coverage and a dual overlapping front flap to help seal out the weather. The higher-cut waist on the pants insures that they will stay overlapped by the jacket - the last thing you want is for the jacket to ride up and expose your lower back to the elements. Both the top and bottom run large, allowing them to be easily worn over your gear. This does mean that there will be extra material in some places, but the adjusters in the collar, sides, waist and ankles that allow you to tighten it up to prevent the material from flapping at speed.
Rain gear doesn’t do you any good if you don’t have it with you when the weather starts to turn, so Alpinestars made sure that the Quick Seal Out set is compact and easy to transport. Both the jacket and pants easily roll up and slip into the included carrying bag. When packed, these will fit in just about any compartment or bag.
Be prepared for wet weather by ordering the Alpinestars Quick Seal Out 2PC Rain Suit from Riders Discount today! Your have your choice of black or high-visibility yellow can be found here:
Alpinestars Quick Seal Out 2PC Rainsuit - Riders Discount
Feel free to get in touch with Brad if you have any questions. You can give him a call at 866-931-6644 ext. 810, or send him a PM through the forum. You can shoot an email to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away.
Dual overlapping front flap helps seal out the elements.
Once rolled up and packed in the included bag, the Quick Seal Out is easy to bring with you on your ride.
1 - 1 of 1 Posts
