do you have a full system SS? If its a slip I can send you my map. Though we are at way different sea levels..ect..
Target AFR Mine is at 13:2 though I think. I think its 13:0 from factory. Not sure though
haha. I wish. Only thing I know about motorcycles is that they are expensive.
lol...
AFR air to fuel ratio.
SO you have a Yosh full system and a Bazzaz Z-fi? Do you have the Bazzaz AFM? The afm is the module that takes readings from a sensor you install in pipe and auto corrects the ecu based on the AFR you want to run. If you just have the Z-fi and you install it, it has a map that Bazzaz did on a CBR nack in chino hills. Should be better than your stock ecu mapping but the sea level/atmospheric pressure effects things and Bazzaz is in a place 1200 feet above sea level. Also tuned to a slip on and not a full system.
If you have the Z-FI and AFM you can just ride it out and it will adjust. If you only have your Z-fi then You will need to hit a performance shop and have them dyno the bike and tune it specifically to your bike. ESP with a full system. It prolly running so lean right now. I also suggest removing your snorkel from the airbox before the tune if your running at higher rpms.
AFM is 299
you could prolly get a custom tune for 200.00
but for 100 extra bucks, you'll always be getting peak performance.
If you only have your Z-fi then You will need to hit a performance shop and have them dyno the bike and tune it specifically to your bike. I also suggest removing your snorkel from the airbox before the tune if your running at higher rpms.
AFM is 299
i got both the Z-FI and the AFM (i like to cut out the middleman for $100 please)("let's make a deal" voice)
im running map #1 which i almost %100 sure is for aftermarket exhaust
...but i would like to leave that map just in case any abnormal reading or i get stuck or something , so i will try to self-map #2.
would like a hwy map and a city map (translation) > track map or stunt map
if you have any more suggestion , keep'em coming please
The simple answer is somewere between 13.2 and 13.5 for a stock motor with pump gas and stock ignition.
I had mine tuned for 2 maps and I can pop in a little dongle to switch them. I never do. Just keep my turbo map rocking all the time.
You will lose a little gas milage but not enough to make you wanna sell your bike. Your gonna be on your throttle full on all the time anyway. (MY gsxr with sprocket conversion and tune is getting 25 now running 93. fn bull) think it needs a new tune.
my bike is gear'd already so the MPG thing when out the window (was never really a mpg's fanatic , but when i think about it , i just look at the other vehicles around me)
..soooo, set the afr at like 13.4 , hit start and ride around with lost of roll on's on all gears !?
get back home , hit stop , retrieve and apply !?
What are we looking at on the graph? Stock pipe and stock map vs. loud slip on and Bazzaz? The stock pipe that is pictured looks a little extra low on power in the 3-5,000 range compared to many other dyno printouts I have seen.
Mr. Bazzaz or anyone competent enough to answer:
Is this unit has the same problem with Dynojet's unit regarding O2 sensor like it does not not allow fine tune on AFR around 85 percent blah blah blah?
I am asking this questions on this forum for a long time and so far no one answered or enlightened us on "no fine tune adjustment around 85 percent on AFR due to O2 sensor" What does it officially mean guys?
This is the key question for me to buy the ecu or not and i am sure for many here. As, i do not see/hear any explanation about it, i afraid that, ecu manufacturers hide the truth from us?
Any answers?
Thanks in advance.
This is the key question for me to buy the ecu or not and i am sure for many here. As, i do not see/hear any explaination about it, i m afraid that, ecu manufacturers hide the truth from us?
Any answers?
Thanks in advance.
It is sad to quote on my own post!
no answer again which make me think again like the ecu is not working correctly and manufacturers hiding the truth or you guys are just hooked on a placebo effect maybe?
Is it sad but true?
Or, no one here is competent enough to answer?
I m not sure, let' see.
Well when we tuned the bike we did it a base of 13.0 AFR.
Here is the procedure to tune your bike when using the ZAFM
1: Plug into the software on go into the Self Map Tab
2: Press Start/Exit the Soft ware
3: Ride the bike for a good 20 min. Try to hit every gear
4: Plug back into the Software/Self Map Tab
5: Press Stop
6: Press retrieve
8: Press Apply All
9: Press Clear
10: Repeat in same order
I could never find this when I needed it, besides the OP link and pressing zoom over and over... and over. This should help a lot of people out who are looking for this info...
That torque boost is incredible. Totally getting one of these to help my constant city commuting.
Very little of that improvement is coming from the box. They are obviously comparing a stock exhaust to a slip on. Every dyno with a modified exhaust that I have seen looks about like that. The slip on alone will give you most of the gains (and a ticket grabbing amount of noise) and the fuel controller is just the icing on the cake to richen up the bottom end where the Honda maps are actually into a lean burn.
Are you saying the Z-Fi won't do much with stock exhaust? I saw this review...
For those who don't watch the video, Motorcycle Daily is reporting an obviously noticeable difference with no modification to the intake or exhaust at all.
I wondered about that article when I first saw it. Might be worth a try I guess. Especially if you get the whole kit with the auto logger and quick shifter.
All I can say is I had the Z-Fi installed yesterday, with the slip on map (map 1) - also I have an Akrapovic carbon slip-on (db killer is in). No dyno.
Some immediate observations:
1. Much smoother throttle in the lower gears - didn't get past 4 on ride home so haven't tested higher yet. 1st is actually usable now - can ride around at reasonable speed with lower gears, which is great. No more starving puttering sound, if that makes any sense. More fuel
2. The exhaust sound has changed dramatically - it sounds aggressive all the time vs some of the time as before - in a highly melodious way.
3. Definitely feels like the engine response and power has increased. If I had to describe it in one word, its "useful". Bike responds faster and fluidly - much more fun to ride.
4. Set off car alarms coming home - huge grin on face.
Just get it, if you can. Akra + Bazazz = a whole different bike. I put 600 miles on just Akra so far, so I'm reasonably qualified to make this observation.
Are any of you guys seeing a decrease in fuel economy with the Bazzaz Z-Fi? I'm contemplating one, but won't get it if it drops my mileage into the 50's.
Why get a fuel controller? Alone it will only gain you a few tenths of a hp and only below 5,000 where Honda has the fuel map set ultra lean for economy. Did you change the exhaust to a loud slip on yet? That will give you 1.5 hp at 8,700 by itself. And might increase fuel mileage on the highway at part throttle from being less restrictive.
The motorcycle.com review I posted the YouTube video to on the previous page was claiming it was a very noticeable difference even with no modification to the exhaust. They said their mileage dropped from upper 60's to upper 50's. I was just wondering if anyone had any experience with it.
They said the fuel controller made " much more power" but never substantiated it with the dyno they promised that I can find. The dyno at the top of this thread looks exactly like all the others I've seen that installed a slip on only and they never replied when I asked them if that is showing a fuel controller AND a slip on. You could try it along with the auto logger with some timed runs but I think you will still be looking for a slip on to make any real difference above 5,000. And fuel economy will certainly go down the more you richen it.
I was hoping to make the boost below 5k for getting off the line when commuting in traffic. The dyno sheet on the last page shows a bump in torque in the bottom end. Do you think that came from a slip on? My understanding was that a higher flow exhaust would add power to the top end, not bottom. My theory was that if the 250R runs lean <5k, a fuel controller richening up the ratio would add more to that range most. Is this incorrect?
That would be a deal breaker if so. I don't want a loud exhaust. Had one before and got tired of it after a few hundred miles. I started feeling embarrassed at all the obnoxious noise I was making everywhere I went. Could be wishful thinking to think the Bazzaz on a stock CBR would add low end torque by itself and only lose a couple of MPG's. Maybe the richer fuel mix accounts for the torque gain more so than a more free flowing exhaust? Perhaps the map gives the low end gains and the slip on gives the high end gains?
You are wishfully thinking. Just like they want you to so you will buy a fuel controller. Even if you were to take the mixture to 13.0:1 from 3-5,000 which is the only place that Honda is running the stock maps lean, whatever you gain in power, you will lose in fuel economy.
Rusty, Honda certainly detuned it a bit to give greater fuel economy, so I have no doubt that you could get a 1-1.5hp gain without touching the exhaust or intake.
Personally I don't think any of these things (intake, exhaust, ECU piggyback) are worth it from a performance standpoint. If you're after looks, a different sound, etc., then sure.
(Disclaimer: I'm not really a killjoy, honest. I've probably spent twice what my car is worth on 'go fast' mods. If I felt the gains from these products were worth it, I'd be all over them.)
Until I see some hard data on the questions we're speculating on answers to, there's no chance I'm spending the money buying a Z-Fi and having it dyno tuned in hopes of gains of low end power.
The reason I am against the possibility of major gains with just a fuel controller is the side by side dynos that TwoBros published showing a slip on without fuel controller and a slip on with fuel controller and the power curves are almost the same.
They say "with and without tip". I'm not sure what that's referring to. Where does it say that it's with and without fuel controller? OR, or, or... do I just not know what a "tip" is?
I don't know quite what to make of that.. maybe the "juice box" just sucks compared to the others? They're showing a 0.1hp gain having it vs. not.. which isn't just miniscule: it's within the margin of error of the dyno run I'd bet.
21.2K members
