changed the oil and filter today..had about 3500 miles on the oil in there..it was still nice and golden but a few shades darker than the new oil that replaced it..I dont see why it couldn't have went another 3500 miles before changing..easy.....so ill just change it about eveyr 7-8000 miles or once per year like the manual states
And whats up with the drain bolt? first of all why make it a star bit? luckily i had some in my toolbox....I don't know why make it a different kind of bolt than seen anywhere else on the bike (does Honda manufacture star bit sockets?) probably
And the fact that its just slightly off center from top dead center over the exhaust pipe? I had my socket turned at a slight angle to be able to get it into bolt..then when the oil comes out..guess where it goes..yep....all over the exhaust..my attempts to get my bucket all the way under it or use the funnel i had sitting there was futile at best...a good 3/4 of a quarts puddled right on the concrete under my motorcycle...put a bunch of shop rags down to soak up what i could...ugggg
And even tho Honda dealer said I didn't need to change the gasket I had them order me one anyway because I believe the service manual says to? it was just $3.25.....but they were right..the gasket is metal and I could tell not one tiny difference between the new one and the old one if not for the slight sheen of oil on the old one....I wont bother changing it again for awhile..maybe every 5 oil changes or so....my dealer also said to replace the drain plug ever 5 or 6 oil changes...ill prob order them together and change them at the same time to make it simpler to remember.
