1 - 2 of 2 Posts
I am going to purchase 2011 model cbr 250r
The bike hasn't been stated in past 4 years it's not starting now regardless of everything is fine expect there is no power coming on spark plug
Kindly help me solve this issue
Drain fuel tank, check interior condition, add fresh fuel with fuel system cleaner, replace battery, keep battery charger handy, check air filter condition, check the oil level, check the coolant level.
You may need to pull the fuel injector if it's hopelessly plugged from old fuel sitting in it.
It's probably going to take a bunch of cranking, so keep track of the battery. Sometimes opening the throttle slightly as you are cranking can help with problematic starting.
1 - 2 of 2 Posts
