Model Year: CBR 250r 2011
Odometer (Miles/Km's): 41,000 Km
ABS model?: No
Description of the Problem: Start Motorcycle, turns on fine, but will die after about 3 seconds. I can engage the throttle and the motorcycle will stay on. As soon as I let the throttle go, the motorcycle dies. I can ride it, but cannot idle it at all. Have to manually engage the throttle to keep the RPM at 3k, to keep it running.
Operating Conditions when Problem occurs: Pulled motorcycle out of garage and tried to start it, but the problem started.
Service History/Previous issues regarding this bike: Changed Spark plug 1.5k km ago. Do regular maintenance and have been riding it for 8 years. No issues other than transmission plates being replaced at about 34k. I changed the oil 7 months ago, or 1.3k KM ago.
Aftermarket Parts & Accessories installed on the bike: None.
Any other information that may be relevant to the Problem/Issue: I have fully charged the battery with a trickle charger. The battery is 18 months old. I reset the ECM. I changed the air filter. Checked the air intake for obstructions. Refastened the battery lines.
Other Solutions that involes spending money to find out if it fixes the problem.
Fuel Line Filter.
Running Lean.
Bad compression.
Throttle sensor needs to be replaced.
Other solutions are appreciated. A confirmation of a solution would be astounding.
ABS model?: No
Fuel Line Filter.
Running Lean.
Bad compression.
