It only cut off idle when it’s low on rpm like the idle rpm 1k it will bounce a little and die then when I start it again it does it all over but if I give it a little throttle and I pull up to the next light it won’t do it but then after it happens again only happens when warm when I start it in the morning and for the first time in like 2 weeks it started no problem and idle good day his is with a new oil change , new spark plug, new fuel pump, because my old one fuel valve broke my friend snapped it but I have the old one and I was able to fix it with plastic melt and it’s sturdy but I still put the new pump in the only think to my head is a vacuum leak and the battery is also new the lights are bight also so it give power I use 91 I have a new chain idk what else it can be it happen randomly one day I was riding to Walmart on the road and when I pulled up to a light it just died and wasn’t idling at all so it was a plus I guess he broke it almost 😅 my next purchase I’m thinking is a fuel filter but I feel like I’m spending to much already now for something I feel is small
