1 - 3 of 3 Posts
CBR 250R 2012 fuel indicator blinking,
Hi. Does a fuel pump work? If yes, this is usually a bad contact in the 5-Pin pump connector(the two pins that goes to fuel level sensor), or in the internal two electrical wires that lead to the fuel level sensor.
Reactions: Siddhesh
There are more options (P. 20-19):
  1. If the blinking is short (0.5 second), it is a disconnect matter (which I explained above).
  2. If the blinking is long (1.0 second) then it means that on those wires of the sensor there is a short.
  3. If it is neither disconnect nor short, then the problem is in the combination meter
Reactions: DannoXYZ
1 - 3 of 3 Posts
