Going on a group ride through Utah in June. The planned route includes some off highway riding like the Burr Trail and the Moki Dugway among others. The other riders all have bona fide adventure bikes like BMW GS or Suzuki V-Strom.
My legs are too short to ride pretty much any ADV bike, and in any case I'm not a fan of them. I just can't get into how they look. So, I'm not renting one and I'm not buying one for the trip.
I decided instead to remove the belly pan fairing from my 2012 CBR250R for a little more ground clearance, and also to swap out the wheels and tires. My bike has ABS, which can be a liability or even hazardous on loose dirt and gravel. So I picked up a used set of non-ABS wheels on eBay and mounted a set of Shinko Trail Masters.
The tires are a little larger than stock:
I have about 6" of ground clearance under the kick stand bracket, and 8" under the exhaust pipe. I think it's going to end up being pretty capable. If this "Mad Max" scrambler can't go over some particular piece of rough terrain, neither will I. I'll turn around and find another route to my destination.
I put clear protective wrap on the lower fairings to protect against stones, and I did complete maintenance this winter (bike has 26,000 miles):
- Front: 120/70R17 OEM: 110/70R17
- Rear: 150/70R17 OEM: 140/70R17
- New chain & sprockets
- Valve clearance inspection & adjustment
- New spark plug
- Coolant flush & fill; replacement of both radiator hoses & coolant tank hose
- Rebuild front forks with new seals, bushings, and fork oil
- New dust seals on wheels
