1 - 14 of 14 Posts
This is my sprocket at 28k kms
When did you guys change yours?
My chain still seems alright, the slack is about 1.5 cm and the indicator is just before the red area
That's a pretty good amount of km's to get from a chain & sprocket set... some have had to replace them a lot sooner than that.
Don't just replace the sprocket though... you need to replace both sprockets and the chain as a set. If you don't, the worn chain will take out the new sprocket in short order. Same would be true if you were to install a new chain on worn sprockets.
I replaced my chain and sprockets at 17k miles / 27km. The chain had several tight links, even though I had been fanatical about keeping it lubed. The O-rings must have allowed the internal lubricant to escape...not sure. I did ride the bike occasionally in the winter (only when road surface temperatures were above freezing) and salty water from melting roadside snow piles got on the chain. This may have started some hidden internal corrosion that was not visible on the outside.
Discussion Starter #7
Haha sorry guys I actually forgot to ask the ultimate question...
From the looks of it, does the sprocket need replacing?
My chain got tight links by 14,000 miles. Didn't bother replacing the sprockets.
Actually I was thinking of doing that, just changing to a not so expensive chain and let it wear out since (to me) the sprocket teeth still look kinda good.
What do you guys think?
... just changing to a not so expensive chain and let it wear out since (to me) the sprocket teeth still look kinda good.
As I said in my previous post, if you were to install a new chain on worn sprockets, the new chain will wear quicker than it would on new sprockets. Ultimately you'd end up spending more money, not less, by doing that.
You said in your first post that you had some axle adjustment left... if it were me I would either run those chain & sprockets 'as is' a while longer, or just replace them now. Either way, worn out chain & sprockets should be replaced as a set.
When replacing sprockets, is it customary to replace both the engine side and the tire side at the same time? Or, the tire side tend to wear out faster, so just the tire side?
What about if you replaced the factory O-ring chain at 12k miles and then bought a $25 non o ring chain to use in order to fully wear out the stock sprockets.
This would be a hybrid style approach. What are your opinions on this?
https://www.amazon.com/NICHE-Drive-Standard-Connecting-Master/dp/B07VFXR32R/
I think if I can get an extra 8000 miles with the non o ring chain (with the remaining stock sprockets) it may be the best way to economize
I'm on my first chain (motorbike is from 2011, it has 14,000 km on it).
Motorcycle mechanic said it should be changed at 20,000 km. Which is only 12,400 miles. I'm bad bad at chain maintenance. 😏
1 - 14 of 14 Posts
