1 - 3 of 3 Posts
Increasingly, when I pull in the clutch lever, it "catches" noticeably in the first inch of travel. It feels like a little click, and intrudes mildy with interpretting what the actual clutch is doing. I think I've narrowed it down to where the curved metal cable tube enters the clutch adjuster at the lever. If I pull the metal tube away from the adjuster while squeezing the clutch lever, as the tube is pulled toward the adjuster, sometimes it acts like it is hitting a ridge inside the adjuster, and I can feel a "click." Other times not. Anybody experienced this?
Is everything aligned correctly? The "notchy" clutch feel usually occurs just before the clutch cable fails (probably from not re-aligning and lubing).
1 - 3 of 3 Posts
