1 - 7 of 7 Posts
Hi everyone,
Recently purchased a 2012 CBR250R from a private seller and everything was fantastic for about a month until I noticed that the bike was leaking coolant quite consistently. Letting it run on idle would leave a small puddle on the floor.
Video here:
https://www.youtube.com/watch?v=a35q4-X2I-8
I've been reading around the forums and a lot of people say it could be due to the mechanical seal. Since the bike is out of warranty, I'd rather do the replacement myself however from the videos I have seen it seems quite hard to do. Judging from the video and my symptoms, could it be indeed the mechanical seal?
Are you sure it's not just coming from the coolant overflow tube below the bike?
How long are you letting it just sit there and idle?
Long enough for the cooling fan to kick in?
Opps...nevermind. Just saw the video and that sure ain't overflow.
Yes, it would be the water pump Mechanical Seal that is causing the leak.
If you're not comfortable doing the work yourself, I'd recommend having a motorcycle shop replace it.
Thanks guys. After reading about it all last night it seems to be the culprit. I rode it home which took 15 mins and the reserve tank went from upper to half below lower.
Im gonna fill up the radiator and reserve and take it to a shop tomorrow. Ill keep a bottle of coolant in my backpack to top off if I have to lol.
Btw whats the rough cost im looking at here for this repair?
1 - 7 of 7 Posts
