1 - 3 of 3 Posts
I recently dropped my bike to right side and little bit of coolant has been leaked,after i put it on side stand, leakage has stopped? Should i worry about? And whats the minimum level to keep?
If it only leaked while lying on the side it shouldn't have taken damage. There should be an "upper" and "lower" level mark on the coolant reserve tank which is located under the right side of the crank case. Check the level when the engine is at normal operating temp and while the bike is upright.
1 - 3 of 3 Posts
