Hi Steve,
You can press the old bearing shells out with a socket but you definitely need the special Honda tool to install the new ones. I've rebuilt a few engines now and there's really no way around it. The tool clamps the shells and then allows you to press them in (using a hydraulic press) to the proper depth. If you have access to a lathe you could make your own tool for a lot less than the $300 Honda wants for it...
Good luck.
Good luck.
