1 - 4 of 4 Posts
If it's working well, you could remove the lever and clean/lube everything including the lever pivot before disassembling and rebuilding the master.
Discussion Starter #4
I end up just pulling the master cylinder apart, cleaning all of the components, lubing everything with brake fluid (as per manual) and re-assembling. After bleeding the system the brakes are working as normal, without any clicking or grinding.
1 - 4 of 4 Posts
