I totally dissagree with most of what you posted untill I noticed you contradicted yourself! Kinda a double negative. Make up your mind...With cars all around you, don't have anywhere to accelerate to and swerving will only help if you have the shoulder next to you. That's where keeping a watchful eye and predicting problems before you get to them can save your bacon. When literally hundreds of cars are all going the same speed, And if you need to accelerate faster than top gear allows, two quck down shifts puts you right in the power band.![]()
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator shows that @ 55kphHello All,
What do you think about cruising with 3500-4000 rpm? Is it acceptable for our engines? Is it not to low revs?
I mean cruising on 6th gear with about 55kmh (tuck)
Experimented on the way home, at 40 mph (60 km/h) in 6th gear the motor is starting to suffer and needs to be down shifted. I would also agree with Randy in saying it's not safe to ride like that if you might need to accelerate to avoid a accident.Hello All,
NEVER!What do you think about cruising with 3500-4000 rpm? Is it acceptable for our engines? Is it not to low revs?
