My bike has been showing a very annoying issue, Im gonna explain the issue first before my maintenance part to be more complete.
So Issue presented was:
Without messing with the clutch or gear shifting, at the initial moment when opening the throttle to accelerate the bike ''Thumps''. This happens every time especially at lower speeds, instead of a smooth transmission of power it gives this aggressive ''power push''. This only happens the moment I open the throttle and not during the ''rest'' of the throttle opening action. This is a mechanical physical ''thump'' of the whole bike starting from the rear wheel, and not a noise or engine noise ''thump''.
Reason why I think it is the damper set/cush drivers:
At first I thought the issue was too much chain slack , this would create a build up of force before the chain stretched enough to actually transmit power . I tightened the chain and the issue subsided. However I recently learned the chain was actually over tightened as I didn't account for my weight on the bike. After tweaking it to the right place the issue was again more noticeable. I believe the issue relies on the explained core concept however perhaps I was looking at the wrong transmission point for the rear wheel. Because between the rear wheel and chain/sprocket there are cush drivers aka a rubber damper set that cushions the transmission of the chain to the wheel. If the cushions are worn/smooched I expect the same build up of force previously explained to happen.
Ok now for my questions:
First did anyone have a similar issue to what I described and was it fixed by a damper set replacement?
Does anyone know how long a damper set lasts? My bike showed this issue after about 1.5 years of riding and around 15K km.
Does anyone know of good aftermarket damper sets or if they are reliable? Honda ones are ridiculously expensive at 52 euros. I found these guys at wemoto for way cheaper by Schuring and my friend has had to replace them because of the same problem on his bike and for at least a year they have shown no issues. Honda CBR 250 R 11 Cush Drive Rubber Set By Schuring Parts at Wemoto - The UK's No.1 On-Line Motorcycle Parts Retailer
Now for the maintenance, any tips you guys have for someone who never removed the rear wheel? Do I have to realign the axle when putting the wheel back on? Should I use a torque wrench for the 88nm axle nut?
Thanks guys!
Thanks guys!
