1 - 20 of 21 Posts
heard an annoying buzzing sound riding tonight. around 7000 rpm the dash (guages) were vibrating so loud i could hear it thru the helmet and wind. reach up and grab hold and it doesnt do it. anyone had this problem? ill dig into it tommorrow but thought someone might already had the problem.
if you grab the windshield at the top and pull up and down you will hear
a bunch of squeeking and general plastic moving on plastic.
i sprayed WD4o on all the seams on the body work= what a difference
it made.
after a couple hours all the spray will weep out
so you can wipe any excess off.makes the front end seem more
solid with out all the creaking noise.
if in doubt-try it:)
i pulled it apart and didnt fine anything "loose" but when i put it back together i tightened it up a little more. if it does it again on the ride to work ill do something different. it just started doing it all of a sudden.
Banned
it made.
haha.
I'm gonna do that just out of interest. :)
I had the same problem. For me I heard the sound at between 3500 and 4000 RPM.
I tried tightening the screws and tried WD40 but that didn't work.
I found I could eliminate it by putting folded paper in the gap between the shield and dash. I'm going to try to find something more "aesthetic" so that it isn't noticeable or is entirely invisible.
Discussion Starter · #19 ·
yeah im gonna take it back apart when i put the fender elminator on and put the rubber washers on. im glad i work at the dealer.. im putting it on the warranty. lol
as far as the engine rattle.. as soon as someone comes out with a 2 mil piston, ill fix that problem.
1 - 20 of 21 Posts
