1 - 9 of 9 Posts
I was wondering if anyone else has the same problem, but when i'm riding and going to a stop n shift into neutral, then while its still rolling (with clutch in) I down into 1st. But when I do that, I can feel it grinding going into 1st..... Is it supposed to be like that?
Thanks guys
How fast are you moving when you go from neutral to first? If its more than 10-7 mph ive found its a bit rough.
lube your shift lever joints/link meetings and reduce clutch cable tension a bit using fine adjustment nut just after clutch lever,hidden under the rubber thing.
When you put in 1st and release clutch without throttle,bike should not lug,die,but move a little slowly forward.
Thats the right clutch setting.
Check your downshift with that setting.will work smoothly.
Anyway worked for me.
1 - 9 of 9 Posts
