Hi all,
Newbie to the forum here. I have a CBR 250 EFI engine (ABS model) that I bought from a breaking yard (not sure of the year), so I could use it for a go kart. So, it's just the engine along with the ECU and wiring harness.
What's missing - Ignition Key barrel set, Instrument cluster, Pair control solenoid, Bank angle sensor, EVAP solenoids, ABS ECU
Problem - I've got no ignition pulse or Injector pulse. But, when I power the harness, I hear the fuel pump relay click for nearly 4 seconds, which I believe is for priming. I also hear the IACV making noise for a few seconds. All this gives me hope that the ECM is functioning as it should. There is 4V coming out of Vcc terminal of the ECM (Red/yellow wire)
I've tried quite a bit and now I'm at my wit's end. Any direction from you all would be of great help
Test method - I have put a test light in the place of the ignition coil. So, if there is a pulse, the test light would flicker. I have ensured that there is 12V on one terminal. The other wire Lg from ECM to Ignition coil should provide the ground pulse.
Work that I have done so far
- I have put a toggle switch in the place of the ignition key set
- I found a pink wire along with the ignition set of wires (Not shown in the wiring diagram I have). I read that it's the anti-theft system and it needs 9V to enable the ECM. I have done that using a 9v battery now, but still no spark. I saw that in a youtube video, where a guy does that on a CBR 600, and it worked. I tried the zener diode + 1Kohm resistor as well.
- I have shorted the clutch switch terminal wires G/O & G/R to simulate clutch lever is pressed, I guess.
- I'm unsure about the Bank angle sensor. I have a 3 wire plug (Vcc, Gnd, Out) for it on the harness. I have tried to send 0 to 4 V back to the ECM through Out terminal. Still no spark.
- I tried to see if I can get the fault indicator light to tell what code is on there, but connecting a test light between ECM terminal 18 (Wh/Bl wire) & ground, but I got no flashes there. Also tried the test light between pin 18 and battery positive (as I wasn't sure if the control of flashes was with ground or 12V). Still no flashes
- I checked the Crank position sensor output with just a multimeter, I can see changes in resistance value as the engine cranks, so I believe it's good.
