Got started on this as a tangent in another thread, and I thought it deserved its own area.
Let's talk about Honda's incredible tiny inline six race motors of the 1960s.
I came across this article a while back:
Honda RC174 Replica - Classic File - Motorcyclist Magazine
Some excerpts:
Sweet sounding Honda Six ~ Return of the Cafe Racers
You can read quite a bit about these bikes and so much more Honda history in a book of which I have a copy:
The Honda Story:Road And Racing Motorcycles From 1948 To The Present Day: Ian Falloon: 9781859609668: Amazon.com: Books
Some excerpts:
And this page with some video of these 18,000 rpm beasts (they had early issues with stalling when engine speed dipped below 14,000 rpm!):At JPX, the original engine was thoroughly photographed, then carefully stripped, and a detailed assembly handbook created. Every item was measured to the minutest accuracy and X-rayed, and had detailed three-dimensional drawings made-502 in all. Sophisticated hardness testing and metallurgical analysis was conducted on every piece, which revealed some interesting issues. Not a single engine bearing was a standard size, and some of the alloys and surface treatments used were quite unknown to modern science. Soichiro Honda, founder of the company, was also a gifted metallurgist.
The Six's crankshaft is pressed up from 13 components, each no bigger than a domino. Unsupported, it is so flimsy it can be deformed by hand, yet it would have to spin without deflecting at more than 17,000 rpm. Pressing it together with the necessary accuracy-0.01 degree-would require an elaborate set of jigs weighing more than the complete bike; if even one part became slightly misaligned, the entire assembly would be scrap. Ludovic Surcin, designer of the jigs, likened the task to balancing 13 billiard balls on top of each other-and persuading them to stay put.
The engine is riddled with galleries and tiny oilways, unseen by anything but X-ray, with some only 1mm apart. Sometimes two narrow oilways are combined, saving perhaps 0.5mm in width on a single, larger one. Cumulatively this allows the engine to be perhaps 3mm narrower than it might otherwise-yet another minute but worthwhile return on the work involved.
