1 - 20 of 24 Posts
I had my first service performed at Honda of Houston. I brought it in with 730 miles. First thing I noticed was the bike seemed to shift a little smoother. It always shifted smooth, but seemed to get a little less precise further a long the break-in period. It functions perfectly now. It could just be me though. Could be the clutch lever having been adjusted. Anywho. Loving the bike and can't wait to put some more miles on it.
They did seem to fill the bike with oil a tad on the full side.
I'm at 600m but my dealer is so booked, I can't get in there for 3 weeks. I'll probably be at 1000m miles by then.
I had mine serviced at honda galveston, no problems with oil level. But they did call and ask if my rear seat flew off on the way home because technician thought he forgot to secure it lol.
Finally got a chance to get my bike in for service on Apr12 with 2100km on it. I did get oil and filter done in Nov2011 at 660km. The only issue i had was after i got bike i rode for a few km and stopped to pick up something. noticed a drip of oil on ground and looking closer the inside right faring was covered in oil. Oil level was ok.
picked up new item (tank bag) and headed back to shop to make sure there is no problem. checked for oil at stop lights on way back. looked ok. Stopped and dealer and there was a drip of oil and oil on faring again but less than previously.
Turned out to be nothing serious. some oil pooled on lip by oil filter that wasnt wiped up. The other thread about oil change here helped me visualize what it was.
was a great weekend and managed to tac on another 600+km ... and lol. was admonished by the service tech. (reminded me of that Seinfeld episode with the mechanic ragging on Jerry about his car)
Said i should check my tire pressure more often. i do each week. but kept it at 29/29 but he said i should be at 33 on rear ( i weigh approx 195LB)
I was going to do the 600-mile service myself (or at least my mechanically-inclined handy-dandy husband was going to do it for me!) :D However, I'm reading about valve clearances (don't even know what that is) and sounds like it requires special tools. Guessing I need to call my dealership in the morning and schedule an appt. :confused:
You might want to consider if doing your own service voids your warranty. Once warranty services are complete then DIY is a good idea. Just a thought
^good to know. Well then, have at er...
If you don't understand what you're doing, then I highly recommend not doing it yourself. Adjusting valves takes time and patience and some tools(like feeler gauges). If you do attempt it, get the Service Manual. All the information is in there.
If you check your own valves & they are out of spec. Then what? Put your bike back together till you get the correct shims? Glad i took mine in, valves were tight. If I would of did it, i would of had to do the math a get correct shims and the risk of dropping one down in the motor. No thanks. Only cost $178 dollars. They got the headaches. Decided they can do my wifes Rebel to.
never overfill,if you overfill,you can see oil everyday at bottom
of bike,as it escapes through the hoses beneath bike.
And i have checked and confirmed
1.5-1.6 litre-oil change only
1.8 litre-oil+filter
2 litre-disassembly of transmission...
1 - 20 of 24 Posts
