1 - 7 of 7 Posts
Here is an easy and cheap way to fit a hi flow air filter. Buy a standard double layer foam element here:-
eBay - The UK's Online Marketplace
Remove the standard air cleaner and stuff the Ramair element in folded double. Use the side locating wings to position the filter against the upper grill and when replacing the cover fit the protruding square peg below the foam. I also removed the rubber intake trumpet as it has no effect other than to make the hole smaller once the foam is in place.
I'm not making any performance claims at this stage, this is such a cheap mod that you can see for yourself. Its definitely not worse though.
Regards Roadster
Also that the OEM filter has the rubber cage around it for some very good reasons. It wont get sucked up into the engine and it provides a proper seal so that you are getting all filtered air instead of letting non filtered air past.
1 - 7 of 7 Posts
